Fast Ethernet-5 Point
Supports IEEE802.3x full/half-duplex, auto-MDI/MDI-X. DIP switches for built-in alarm relay function, assisting network engineers with notification when port link-down and power failures occur.
  • 12 to 48 VDC terminal block power input
  • Compatible with various industrial protocols of EtherNet/IP, Profinet, CC-LINK IE and DNP 3.0
$85.00
Out of stock
Part number: DVS-005I00 Category:
Excellent ruggedized hardware design of 12 to 48 VDC redundant power inputs and a wide-operating temperature from -40℃ to 75℃ without the use of internal fans are providing superior reliability.ower Requirements Input Voltage: 1 set, 12 to 48 VDC terminal block input
Input Current: Max. 0.24A
Overload Current Protection: Present, Max. input current 3A
Reverse Polarity Protection: Present
Buffer Time: Min. 13ms at 24VDC Environmental Limits
Operating Temperature: -10℃ to 60℃(14℉ to 140℉) , tested @ -25℃ to 70℃(-13℉ to 158℉)
Storage Temperature: -40℃ to 85℃(-40℉ to 185℉)
Ambient Relative Humidity: 5% to 95%(non-condensing)
Dimension
Weight 0.5 kg
