Globe Valve
Globe Valve – BODY ONLY
https://temcocontrols.com/product/globe-valve-body/
The VG Series Valves are designed for hot water, cold water, or steam control in HVAC systems. The globe design displays excellent control ability with two-way equal percentage and three-way linear response. The valves come in two-way or three-way NPT or flanged thread configurations. Each valve can be fitted with many different control actuators (both electric and pneumatic) and with a variety of control signals, spring ranges, and fail safe operation.
Motorized Globe Valve
Temco’s VLV-GL Series Valves accurately regulate the flow of water or steam in response to the demand of a controller in HVAC system.These valves are available in normally open, normally closed, and three-way mixing configurations.Both electric and pneumatic actuators can be used. Valves are available in 1″ through 6″ sizes.
Model
TWO-WAY VALVE SPECIFICATION |
Actuator | Torque |
Dimension <mm> |
Flow Rate (KV) |
Max Pressure Difference (bar) |
Valve stem stroke |
VG-2WFL-DN25 | VA-3500 | 1000N | 25 | 10 | 2.0(10) | 17 |
VG-2WFL-DN32 | VA-3500 | 1000N | 32 | 16 | 2.0(7.5) | 19 |
VG-2WFL-DN40 | VA-3500 | 1000N | 40 | 25 | 2.0(5.0) | 19 |
VG-2WFL-DN50 | VA-3600 | 1500N | 50 | 40 | 2.0(3.0) | 22 |
VG-2WFL-DN65 | VA-3600 | 1500N | 65 | 63 | 2.0(3.0) | 25 |
Model
THREE-WAY VALVE SPECIFICATION |
Actuator | Torque |
Dimension <mm> |
Flow Rate (KV) |
Valve stem stroke |
VG-3WFL-DN25 | VA-3500 | 1000N | 25 | 10 | 2.0(10) | 17 |
VG-3WFL-DN32 | VA-3500 | 1000N | 32 | 16 | 2.0(7.5) | 19 |
VG-3WFL-DN40 | VA-3500 | 1000N | 40 | 25 | 2.0(5.0) | 19 |
VG-3WFL-DN50 | VA-3600 | 1500N | 50 | 40 | 2.0(3.0) | 22 |
VG-3WFL-DN65 | VA-3600 | 1500N | 65 | 63 | 2.0(3.0) | 25 |
