Outdoor Weather Station
Outdoor weather station with humidity, temperature and light level sensors  helps with free cooling strategies and other energy saving routines. The sensor communicates over both Ethernet and RS485,  using BOTH Bacnet and Modbus protocols so there are many ways to integrate into the system.
  • Bacnet and Modbus over Ethernet: standard
  • Bacnet and Modbus over RS485: standard
  • Good long term stability and reliability
  • 100% field changeable sensor, free calibration services.
  • Dew point and enthalpy are calculated and available over the com ports.
  • Durable ABS Plastic housing with UV protection additives.
$85.00
Stock : 9 in stock
Part number: WS-1-D Category:
Weight 1.50 kg
