RTS Wall and Bead Sensors
The room sensors are used to provide reliable, accurate temperature readings in surface-mount room environments, Energy Management Control Systems, compatible with all the leading control systems.They feature a standard plastic ventilated enclosure.
  • Three low cost room temperature sensors to choose from.
  • High precision thermistor or RTD, accurate to 0.2C(+/-.36F).
  • The platinum RTD is accurate to 0.4C.
$1.00 - $3.50
Room Temperature Sensor
RTS:
RTSrts_dimension
RTS-Raw
rts-raw_dimensions
RTS-Bead
rts-bead_dimensions
Weight 0.01 kg
RTS type
RTS, RTS-Bead-120, RTS-Bead-4, RTS-RAW
10K Type 2, 10K Type 3, 1K PT
