TF50-P Flow Switch
Water Flow Switch, Stainless Steel Paddles, brass fittings, SPDT switch, liquid, water, ethylene glycol solutions.The TF50-P Flow Switch is used to prove flow in liquid lines using water, ethylene glycol solutions, or other liquids compatible with brass and phosphor bronze parts. The SPDT contact switch is activated by the flow of liquid through the pipes. The set point is adjustable.
  • Can be adjusted to switch at various flow rates
  • Uses an SPDT switch with high power rating for up to 3.5 A continuous, 21 A surge
  • Non-Corrosive plastic ABS cover
  • Brass Fittings
  • Stainless Steel Paddles
  • Functions in liquid temperatures of 0~120°C (32~248°F)
  • Max working pressure: 13.5 bar(193 psig)
$24.00
Stock : 58 in stock
Part number: TF50-P Category:
TF50-P Flow Switch
The switch is available for 1/2″ NPT and 3/4″ NPT pipe. They include a stainless steel paddle in three segments for pipes 1″ to 3″ (2.54 to 7.62 cm) in diameter. Paddle segments may be removed or cut as needed. A 6″ (15.24 cm) paddle is also usable in a 4″ (10.16 cm) diameter pipes and larger.
Dimension:wfs_2_dimension
wfs_2_paddle
wiring-diagram
Weight 0.57 kg
