Temperature and Humidity Transducer with Bacnet and Modbus RS485
-High precision sensor accurate to 2% humidity over the entire temperature range.
-Duct mount style is suitable for typical HVAC and agricultural applications
-Field selectable span for the temperature range
-100% field changeable sensors, no re-calibration needed
-Jumper select the output signal: 4~20mA or 0-10V
-BACnet MS/TP and Modbus RTU protocols over RS485.
-Enthalpy and dew point are available over the RS485 link
$25.00$30.00
Part number: Transducer Category:
Duct temperature and humidity sensor / transmitter well suited to all types of  building automation and environmental monitoring applications. The transducer offers two options for intefacing to the automation system, either with an analog signal or over the RS485 network using either Bacnet or Modbus RTU protocols.
The analog signal can be field selected by moving a jumper, either 4-20ma or 0-10V full scale signals are available. The full scale range of the temperature signal can also be field selected by moving a jumper from three different ranges.
When communicating over RS485 the enthalpy and dew point are available as either Bacnet AV’s or Modbus registers. Use our free T3000 software application to configure the baud rate, network ID for modbus, or the Bacnet instance number.
Dimension
Module type
