Pressure Transmitter
Single Ended Pressure Transmitter is a kind of standard and most popular transmitter applied in air and liquid pressure measuring,since a high sensitivity silicon pressure chip is employed in the sensor.</p>
$38.00 - $71.00
A Pressure Transmitter plays a vital role in modern industrial systems by providing accurate and reliable pressure measurement. This transmitter is expertly designed to meet the needs of diverse industry applications, offering exceptional long-term stability—an essential requirement for maintaining consistent system performance. Whether used in automation, process control, fluid systems, or industrial machinery, it ensures dependable monitoring even in challenging operating conditions.
Built with advanced sensing technology and high-grade materials, this transmitter delivers precision, durability, and reliability. Its piezoresistive sensing element enhances accuracy, while the rugged stainless-steel construction ensures compatibility with a wide range of gases and dilute liquids. This makes it suitable for industries that demand consistent measurement, minimal maintenance, and long service life.
Why This Stands Pressure Transmitter Out
This transmitter is engineered to support critical industrial operations by maintaining accuracy over years of use. It withstands fluctuating environmental conditions and delivers consistent output with minimal drift. The result is a device that not only performs exceptionally but also contributes to improved safety, efficiency, and process optimization.
Key Features
  • Advanced Piezoresistive Pressure Sensor
    The transmitter incorporates a highly sensitive piezoresistive sensor that provides stable, precise, and repeatable pressure readings. This ensures optimal performance in pressure monitoring and control systems.
  • Wide Pressure Range Options
    Available in multiple pressure ranges—0–700 psi (4.8 MPa) and 0–400 psi (2.8 MPa)—allowing you to select the right configuration for your specific industrial application.
  • 316L Stainless Steel Compatibility
    Designed for use with gases or dilute liquids, the transmitter’s 316L stainless steel construction offers superior corrosion resistance, ensuring long-term durability even in harsh environments.
  • Exceptional Reliability & Long-Term Stability
    Built to deliver consistent output with minimal drift, this pressure transmitter is ideal for long-term industrial use. Its stable performance reduces maintenance costs and ensures uninterrupted operation in critical applications.
Applications
This Pressure Transmitter is ideal for:
  • Industrial automation systems
  • HVAC and fluid management
  • Process control and monitoring
  • Mechanical equipment and hydraulic systems
  • Chemical and petrochemical environments
  • Water and wastewater management
Delivering Performance You Can Trust
With its robust design, high-quality components, and advanced sensing technology, this pressure transmitter is a dependable solution for industries that need precise, long-term pressure measurement. It boosts operational efficiency, enhances system safety, and delivers reliable performance across a wide range of applications
Wiring Connection:Pressure Transmitter wiring connection diagram showing terminal layout尺寸:
Pressure Transmitter dimension diagram with length and diameter details
Technical dimension drawing of Pressure Transmitter for installation reference
重量 0.39 公斤
Pressure range
0-100[0.7Mpa], 0-250[1.8Mpa], RTD2, 0-1000[6.9MPa], 0-2000[13.8MPa], 0-2900[20MPa], 0-400[2.8MPa], 0-700[4.8MPa]
