Tstat9 Bacnet Thermostat
  • Modbus TCP/lP protocols over WlFl.
  • 良好的文件记录清单,便于与其他系统集成
  • 5 relay outputs, each rated at 100~220V, 5 amps.
  • Color LCD display
  • 轻松配置几乎任何应用的恒温器
  • 使用具有12位模拟读数的32位Arm CPU
  • Fits in regular 3in*3in*1.4in(88mm*88mm*35mm) electrical box
  • Al:10K thermistor.AO: 0-10VDC
$56.00 - $65.00
This full featured thermostat is designed for line voltage cooling and heating systems in residential and commercial buidings. The thermostat can be configured for or use with air handlers, fan cols, VAv, modulating valves and practically any HVAC application.All models support Bacnet and Modbus protocol over the Wif iP connection which aows easy integration with the big name control systems like Niagara, Siemens, Honeywel. lohnson Controls ,Delta,Reliable and Kreuter to name a few. We also provide our free and easy to use T3000 front end which can provide a full system level solution for large buildings, hotels and commercial buildings.There are five 220v, 5A rated relays outputs. These outputs can be configured using thefree software.There are more than 300 setings with many options for each other setings so its possilble to contgure these devices for most anvapplication. Once the unit is configured, save the config file for copying to other controlers and backing up project seltings. Options are available foroccupancy sensor, wifi, CO2 and humidity/enthalpy.
Wiring Diagram 1
Smart WiFi HVAC thermostat”
Wiring Diagram 2Commercial and residential thermostat
Wiring Diagram 3
BACnet Modbus smart thermostat
Wiring Diagram 4220V relay HVAC thermostat
In conclusion, this full-featured HVAC thermostat offers unmatched flexibility and integration for both residential and commercial buildings. With support for BACnet and Modbus over WiFi, configurable relays, and advanced sensor options, it provides a reliable and efficient solution for any HVAC application. Its easy-to-use T3000 software ensures seamless setup and management, making this HVAC thermostat the ideal choice for modern building automation
Humidity
Humidity, No Humidity, With Humidity, Without Humidity
OCC
NO OCC, OCC
Communications
RS485, Wifi+RS485
