Tstat8 Bacnet恒温器
这款全功能恒温器专为住宅和商业建筑中的制冷和供暖系统而设计。
Attention: The Tstat8 is our legacy product, for new projects please consider the Tstat10https://bravocontrols.com/shop/tstat10-bacnet-thermostat/
  • RS485上的Bacnet MSTP和Modbus RTU协议
  • 波特率分别为1.2k,4.8k,9.6k,14.4k,19.2k,38.4k,57.6k,76.8k和115.2k
  • Well documented Bacnet Object list and Modbus register list for easy integration
  • 8 universal inputs for external temperature, dirty filter sensor, air flow, door switch , etc.
  • 5个继电器输出,每个输出额定在12到24vac,2安培
  • 2个模拟输出,0-10V @ 100ma
  • 彩色液晶显示器,2.4英寸对角线
  • 轻松配置几乎任何应用的恒温器
  • 时钟与无限的生活超级电池备份
  • 使用具有12位模拟读数的32位Arm CPU
  • License free, Open source T3000 front end for configuring and managing systems
$64.00 - $112.00
Tstat8 Bacnet恒温器
The Tstat8 Bacnet恒温器 is a versatile HVAC control solution designed for use with air handlers, fan coils, VAV, modulating valves, and practically any HVAC application. Its wide compatibility makes it ideal for integration into modern building automation systems.
Key Features
  • Protocols & Connectivity: Supports BACnet MSTP and Modbus RTU protocols over RS485 for seamless integration with major control systems including Niagara, Siemens, Honeywell, Johnson Controls, Delta, Reliable, and Kreutzer. The new WiFi version also supports Modbus, with BACnet over IP coming soon.
  • Flexible I/O: 8 universal inputs for external temperature, dirty filter sensors, air flow, door switches, and more. 5 relay outputs rated 12–24VAC, 2A each, and 2 analog outputs, 0–10V @ 100mA, enable precise control of HVAC devices.
  • Advanced Display: 2.4-inch color LCD display provides clear readings and intuitive interface.
  • High Performance: Powered by a 32-bit ARM CPU with 12-bit analog readings, ensuring fast and accurate performance.
  • Customizable & Configurable: Easily configure the thermostat for nearly any application. Hundreds of settings allow full customization using the free and open-source T3000 front-end software. Once configured, settings can be saved and copied to other controllers for quick deployment.
  • Reliable & Practical: Features a clock with an infinite-life supercap battery backup, ensuring continuous operation during power interruptions.
  • Centralized Management (Optional): Pair with T3 series programmable controllers for gateway functionality from RS485 to Ethernet, centralized scheduling, zone management, graphical floorplans, data logging, and alarm generation.
Why Choose the Tstat8 Bacnet Thermostat?
The Tstat8 Bacnet恒温器 combines advanced connectivity, flexible I/O, and intuitive configuration in a compact, reliable package. Whether working stand-alone or integrated with larger control systems, it delivers precise HVAC management for modern buildings. With well-documented BACnet object lists and Modbus registers, setup and integration are seamless, saving time and effort for contractors and engineers alike.
Explore the Tstat8 Bacnet Thermostat today for a versatile, reliable, and fully configurable solution for your HVAC control needs.
Tstat8 Bacnet Thermostat with display and control buttons
与大型系统中的主控制器一起工作,或者为了更简单的系统,恒温器可以独立运行。
 Front view of Tstat8 Bacnet Thermostat for HVAC systems
接线图:Tstat8 Bacnet Thermostat wiring diagram showing input and output connections
零件号码方案:
Tstat8 Bacnet Thermostat part number scheme for model identification
注意:Tstat8的Balck颜色是可用的,最小的顺序是50。
与...合作: 继电器板
With powerful integration options, flexible I/O, and advanced configuration capabilities, the Tstat8 Bacnet Thermostat delivers reliable performance for a wide range of HVAC applications. Its adaptability and smart connectivity make it an ideal choice for modern building automation.
重量 0.25 公斤
C02
C02, No CO2
OCC
NO OCC, OCC
Humidity
With Humidity, Without Humidity
Wifi
RS485 + wifi, RS485 only
