Retrofit Valve Actuator
Actuator, 1000N torque, 24VAC only, with self-stroke adjustment, with 0(2)~10Vdc or 0(4)~20mA DC input control signal and 0~10Vdc feedback signal,with manual operator
• Low AC voltage synchronic reversible motor.
• Hall switch sensor
• Self-adjusting function, automatic record stroke data
• Working state (DA or RA) can be selected by jumper.
• 0(2)~10V DC or (0)4~20mA DC input signal control, proportional control
• 0~10V DC feedback signal.
• Valve plug position indicator
• Fire-resistant ABS plastic casing.
• Conveniently mounting.
• Is a direct replacement part for Honeywell ML7984A4009
$120.00
股票 :
无货
零件号: VA-3503M 类别:
VA-35(6)00 Retrofit Valve Actuator is an intelligent electromechanical product designed for HVAC systems. When paired with the VB-3000Q valve body, it ensures precise flow rate control and efficient operation.
Wiring Diagram
Wiring Diagram of VA-35(6)00 Retrofit Valve Actuator
Dimensions
Dimension of VA-35(6)00 Retrofit Valve Actuator
In conclusion, the VA-35(6)00 Retrofit Valve Actuator offers reliable performance and precise flow control for HVAC systems. Its intelligent design and perfect fit with the VB-3000Q valve body ensure smooth performance. It helps achieve better system efficiency and accurate control.
重量 2 公斤
