The RZ021-10A-G(No Neutral Required) is an US style 5A wall mounted occupancy sensor switch which uses advanced passive infrared sensor(PIR) and MCU control.
3 in 1 Occupancy&Vacancy&On-Off sensor switch adjustable.
Use fireproof material, high security.
Built-in magnetic latching relay, compared to traditional relay, better performance.
Digital scale on time delay, 15seconds, 1mins, 3mins, 5mins, 15mins, 30mins(6 time delay modes adjustable).
Surface buttons to change the function mode directly, free removal.
Accept function customize, like delay time, light sensor value as you request
The RZ021 series motion sensor sensor switch automatically turns lights or fans on and off by sensing movement heat, replacing a standard light or fan switch.
The products use advanced passive infrared sensor(PIR) and MCU control technology which offers better stability than the traditional motion sensor, it’s easy and accurate to adjust the Time Delay, Detection Range, Light sensor value, and operating mode (Occupancy / Vacancy / On-Off )
接线图:
外形尺寸:
Wall Mount:
In conclusion, the RZ021 series Occupancy Light Switch is more than just a replacement for a traditional light or fan switch —It smartly improves comfort, efficiency, and energy savings in any environment.
Built with advanced PIR sensor and MCU control technology, it delivers exceptional precision, faster response, and long-term reliability compared to standard motion sensors.
The switch offers a range of customizable settings, allowing users to easily adjust Time Delay, Detection Range, Light Sensor Value, and operational modes such as Occupancy, Vacancy, and On-Off, ensuring it perfectly fits diverse needs and spaces.
From homes to offices, schools, and commercial buildings, the RZ021 series offers smart control and convenience. It reduces energy waste while improving the overall user experience. Its smart design simplifies routines, saves energy, and promotes sustainable living. This makes it a valuable addition to any modern lighting system.
Holiday note: Our office will be closed from February 11th to February 25th 2026 for Chinese New Year Holiday, and we will resume work from February 26th 2026. Dismiss
