Find all 1K Pt temperature sensors in one place, featuring multiple housing options and customizable designs to suit any application.
  • Class A accuracy,  < +/- 0.2C over typical range.
  • Long term stability
  • Low cost sensors for typical building applications.
  • Custom models with higher temperature rating, higher accuracy and housings are available on request, small minimum order requirements.
$1.00 - $9.40
Here are all the 1k Pt sensors from our various models grouped into a single page for easy reference for users of 1k Pt type sensors. You’ll find these sensors under the “1k Pt” sensor type across the site.
This page lets you browse them more easily by housing. All models are here including the duct, water immersion, flange, outside and various room mount options. If you don’t see what you need here feel free to ask.
Custom housings, cable lengths, and probe options available. Flexible temperature ratings with low minimum order requirements. We can also brand many of the items with your own logo.
Discover the full range of 1K PT Temperature Sensors designed for versatility, accuracy, and easy navigation by housing type. Whether you need custom lengths, specialized housings, or branded solutions, I’m here to help you find—or create—the perfect fit for your application.
Sensor Type
Duct, Outside, Room, Water
