  • Output 0-330mv
  • Current Frequency 45Hz-65Hz (measured current frequency)
  • Working Environment -20℃~50℃; below 80%rh
  • Storage Environment -10℃~60℃; below 70%rh
$13.00 - $23.00
Part number: CCT-S50-100A-330mV Category:
The Clamp Current Transformer is used for the measurement of AC current, leakage current, high-order harmonic current, phase, power energy, power, and power factor. It is portable and designed with a sharp nose, requiring no disconnection of the measured circuits. Its non-contact operation ensures safety, speed, and convenience during use.
The Clamp Current Transformer is suitable for narrow and densely wired spaces and can be connected with various instruments such as phase detection analyzers, industrial control equipment, data recorders, oscilloscopes, harmonic analyzers, electric power quality analyzers, and high-precision digital multimeters.
It is widely applied across industries including electricity, communication, meteorology, railway, oilfield, construction, measurement, scientific research, and industrial and mining enterprises.
Dimensions
Dimension of Clamp Current Transformer
Part Number Scheme of Clamp Current Transformer
In conclusion, the Clamp Current Transformer is a highly efficient and useful device designed to meet the growing demands of accurate electrical measurement and analysis across various industries.
It enables precise measurement of AC current, leakage current, irregular currents, phase, power energy, and power factor with exceptional reliability. Its portable and sharp-nose design allows users to easily operate in narrow or densely wired environments without disconnecting circuits, ensuring both safety and convenience.
The no-touch measurement feature further improves user safety and efficiency, making it perfect for professionals who need quick and accurate results. It can easily connect with tools like phase testers, measuring devices, power checkers, data recorders, and digital meters, which makes it useful and flexible for different kinds of work environments.
ChatGPT said:
Due to its strong performance and easy operation, the Clamp Current Transformer has become an important tool in industries like electricity, communication, trains, oil plants, construction, weather study, and scientific research. Whether used for field work, factory monitoring, or educational purposes, this device provides high accuracy, speed, and safety — making it a trusted solution for professionals and businesses aiming for reliable and efficient electrical measurement.
Weight 0.6 kg
Primary current
100A, 200A
