Damper Motor
The Actuator is intended for ON-OFF and floating point controls in HVAC systems. It can easily mount on a 1/2″ round or square shaft with solid screw sets. Angle of rotation is mechanically limited to 90 degree. When the actuator reaches its maximum position, the device will automatically stop. An override lever is provided on the side to manually disengage the gear. Two mechanical stops are provided for extra adjustments.
  • Simple Direct Mounting
  • Stall-Proof Synchronous AC Motor
  • Adjustable Angle of Rotation with Mech. Stops
  • Manual override lever
  • Consistent running time
  • Visual Position Indicator
$30.00 - $76.30
Thumbnail SKU Description Stock Price Quantity
DM-20-MOD-24VAC-X DM-20-MOD-24VAC-X
Modulating Damper actuator, 20-nm, 24VAC power, analog signal 0-10V, 4-20ma
$76.30
DM-8-FL-110VAC-X DM-8-FL-110VAC-X
Modulating Damper actuator, 8 n-m, three wire floating control/On Off type, non spring return, 160 seconds, specify 110VAC
5 in stock
$30.00
DM-8-FL-230VAC-X DM-8-FL-230VAC-X
Modulating Damper actuator, 8 n-m, three wire floating control/On Off type, non spring return, 160 seconds, specify 230VAC
1 in stock
$30.00
DM-8-FL-24VAC-X DM-8-FL-24VAC-X
Modulating Damper actuator, 8 n-m, three wire floating control/On Off type, non spring return, 160 seconds, specify 24VAC
8 in stock
$30.00
DM-8-MOD-24VAC-X DM-8-MOD-24VAC-X
Modulating Damper actuator, 8-nm, 24VAC power, analog signal 0-10V, 4-20ma
9 in stock
$45.00
Damper-1S Damper-1S
Endswitch option for DM8, 0 Deg and 180 Deg open contacts
$4.50
Damper Motor
The magnetic clutch allows the device to be operated in the stalled condition indefinitely, no need to interlock the motor at the end of travel. Running time is independent of the load. Two optional end switches provide status points or interlocks for fans & other devices.
2016-11-22-11-50-06
