Outdoor Air Temperature Sensor, Overmolded
Accurate Outdoor Air Temperature Sensor for HVAC systems with a sealed stainless steel probe, PVC radiation shield, 2m cable, and quick-response thermal grease.
  • General purpose outdoor temperature sensor
  • Easy installation – two screws secure the sensor to the wall or an electrical box
  • Fully potted stainless steel probe protects sensing element and provides fast, accurate temperature sensing
  • Cost efficient design
  • Sturdy construction – housing is made from a PVC + rubber blend which resists shock even in cold weather
  • UV inhibitors resist degradation of the plastic even after many years in direct sunlight
  • Operating temperature Range: -40°C to 60°C
$5.00 - $6.00
Part number: OATS Category:
Ensure precise temperature monitoring for your HVAC system with our Outdoor Air Temperature Sensor, engineered for reliability, durability, and quick installation.
  • General Purpose Sensor: Designed to accurately measure outdoor air temperature in typical HVAC applications.
  • Easy Installation: Mounting is quick and simple with just two screws—no electrical box required.
  • Durable Probe: Fully potted stainless steel thermistor provides fast, accurate temperature readings while protecting the sensing element.
  • Cost-Efficient Design: High performance at an affordable price, making it ideal for commercial and residential setups.
  • Sturdy Construction: PVC + rubber housing resists shocks and harsh weather conditions, ensuring long-lasting durability.
  • UV Resistant: Built-in UV inhibitors prevent plastic degradation, maintaining sensor performance even after years in direct sunlight.
  • Wide Operating Range: Works efficiently in temperatures from -40°C to 60°C.
Product Description
Our Sensor is specifically designed for HVAC applications to provide precise temperature readings. The stainless steel probe is sealed and inserted into a hard rubber PVC radiation shield, ensuring durability and fast response.
The two-meter cable allows flexible installation—terminating inside a building enclosure or using flying leads. The cable can exit directly behind the probe or run vertically along the wall. A foam backing insulates the probe from wall heat and seals installation holes. Thermal grease inside the probe ensures rapid response to changing temperatures.
Why Choose Our Sensor?
  • Reliable and accurate temperature measurement for HVAC systems.
  • Quick and easy installation without the need for extra electrical equipment.
  • Durable materials designed to withstand extreme weather conditions.
  • Long-lasting performance with low maintenance requirements.
Upgrade your HVAC monitoring today with our  Sensor—precise, durable, and easy to install.
"Dimension:
unit:mm"Dimension
"</a
Weight 0.08 kg
10K Type 2, 10K Type 3, 1K PT, 3K
