Outdoor Weather Station
Outdoor weather station with humidity, temperature and
light level sensors helps with free cooling strategies and
other energy saving routines.The sensor communicates
over both Ethernet and RS485, using BOTH Bacnet and
Modbus protocols so there are many ways to integrate into
the system.
• Bacnet and Modbus over Ethernet: standard
• Bacnet and Modbus over RS485: standard
• Good long term stability and reliability
• 100% field changeable sensor, free calibration services
• Dew point and enthalpy are calculated and available over the com ports
• Durable ABS Plastic housing with UV protection additives
$93.00
Out of stock
Part number: WS-1-D Category:
Dimension
Mouting
Weight 3.0 kg
