Power Adapter – PA-12V
The product is AC to DC switching power transfer device,of which the black pluggable connector fits onto most Temco products, or can be taken off to connect to your own devices.
  • Input: 120VAC, 60Hz
  • Output: 12VDC, 200mA
  • Color: Black
  • UL certification
$5.00
12 in stock
Part number: PA-12V Category:
Power Adapter PA-12V
This is a reliable AC-to-DC switching power transfer device designed for smooth, consistent performance. Its black pluggable connector is compatible with most Temco products, and can also be removed for custom connections, making it versatile for various applications.
  • AC to DC Switching Power Supply – Ensures stable and efficient power transfer.
  • Universal Compatibility – The pluggable connector fits most Temco devices and you can adjust it for your own equipment.
  • Compact & Durable Design – Sleek black finish built for long-term use.
  • UL Certified – Meets strict safety and quality standards.
Technical Specifications
  • Color: Black
  • Certification: UL Certified
Why Choose Power Adapter PA-12V?
This adapter provides dependable performance, easy integration with various devices, and safety assurance through UL certification. It’s an ideal choice for powering small electronics, Temco units, and custom setups that require a stable 12V DC output.
Power Adapter PA-12V AC to DC switching power supply
Power Adapter PA-12V product dimensions
The Power Adapter PA-12V is a dependable, safety-certified power solution for anyone needing stable 12V DC output. With its versatile compatibility, durable design, and reliable performance, it is an excellent choice for powering Temco products and a wide range of personal devices. Whether for home, office, or custom setups, this adapter ensures consistent power delivery you can trust.
Weight 0.40 kg
