Single phase power meter solutions using CS series current sensors offer versatile compatibility, operating on any 12V to 24V AC or DC supply. These sensors ensure reliable power monitoring with accurate current and voltage measurement. They use RS485 Modbus RTU for seamless integration into your systems.
Product Overview
Our single phase power meter is engineered to deliver dependable performance while maintaining a small footprint and low overall cost. The CS series sensors used with this meter are known for their flexibility and easy installation, making them an ideal choice for both new and retrofit applications.
Key Highlights
Small size, low cost — Ideal for compact installations and cost-sensitive projects.
Latching CT for easy installation — Enables secure, tool-friendly mounting without disconnecting existing wiring.
Wide power compatibility — Operates on 12–24V AC or DC, ensuring reliability across different setups.
High voltage sensing capability — Supports maximum sensing voltage of 480VAC, allowing use in demanding applications.
RS485 Modbus RTU communication — Ensures accurate, real-time access to current and voltage data.
Why Choose This ?
Use this single phase power meter to monitor load consumption or integrate with automation systems. It delivers the accuracy, simplicity, and reliability essential for any energy management application.
Wiring Connection:
