The T3E-6CT is general purpose input / ouput modules for building integrators, providing convenient termination for field devices and interfacing to your HVAC, lighting, temperature sensors, and other typical building control applications.
  • Surge-Protected Analog Inputs with 10-bit Resolution
  • Outputs can Individually be switched to ON, OFF,AUTO
  • High Impact Plastic Enclosure provides durability in commercial environments
  • Standard Modbus Protocol allows for up to 254 unique devices on one RS485 Network
$108.00
14 in stock
Part number: T3E-6CT Category:
T3E-6CT – Advanced I/O Module for Professional Building Automation
The T3E-6CT is a reliable and efficient general-purpose Input/Output module designed for building automation professionals who demand precision, durability, and seamless integration. Engineered to support HVAC, lighting, sensors, and various field devices, it ensures smooth operation across modern automation environments.
1- Surge-Protected Analog Inputs (10-bit Resolution)
Experience accurate data acquisition with robust surge protection. The 10-bit resolution ensures precise readings from connected sensors, enhancing system performance and reliability.
2- Flexible Output Modes: ON, OFF, AUTO
You can set each output channel to ON, OFF, or AUTO, giving you control over connected devices and supporting many system needs.
3-High-Impact Plastic Enclosure
The strong, high-impact plastic enclosure makes the T3E-6CT ready for tough commercial settings. This design protects the internal parts and ensures long-term reliability.
4- Standard Modbus Protocol Support
The T3E-6CT supports the widely used Modbus protocol and connects easily on an RS485 network. It can handle up to 254 devices, making it great for growing building systems.
Weight 0.5 kg
