Moreover, the ME337 panel type Three Phase Multi-function Smart Meter features an external open Rogowski coil or voltage type CT, allowing testing without removing the wire. This design makes the testing process easier and helps reduce construction costs. Additionally, the ME337 supports multiple system setups, including three-phase four-wire, three-phase three-wire, one-phase three-wire, and single-phase systems, making it a versatile solution for various electrical setups.
It can measure multiple electrical parameters such as voltage, current, power factor, signal distortion, power, and energy of A, B and C phases.ME337 is equipped with RS485 communication interface, through the standard Modbus-RTU, protocol, can be compatible with various configuration systems, the front-end collected electrical, parameters instant data transmission to the system data center.
Wiring Terminals:
ChatGPT said:
Three-phase four-wire 3CT
Three-phase three-wire 3CT
In conclusion, the Three Phase Multi-function Smart Meter ME337 is a reliable and efficient solution for comprehensive power monitoring. With advanced measurement features and support for different wiring types, the ME337 makes electrical testing easier. It also reduces overall construction costs.
