Three Phase Multi-function Smart Meter
The ME337 Three-phase power meter with Rogowski coils makes for easy retrofit installation on both three and four wire systems. Supports Modbus RTU protocol over RS485 for integeration into building management systems.
  • Monitors current, voltage, phase angle and many other parameters
  • High precision measurement
  • Modbus RTU communication over RS485
  • Measuring range:0~600VAC Phase voltage
$51.00 - $167.00
Part number: ME337NR2 Category:
ME337 panel type three-phase multi-function power meter, external open Rogowski coil or voltage,type CT, realize the test without removing the wire, simplify the test steps, and save construction costs.ME337 supports three-phase four-wire, three-phase three-wire, one-phase three-wire and single-phase,systems; It can measure multiple electrical parameters such as voltage, current, power factor,harmonics, power, and energy of A, B and C phases.ME337 is equipped with RS485 communication interface, through the standard Modbus-RTU,protocol, can be compatible with various configuration systems, the front-end collected electrical,parameters real-time transmission to the system data center.
Wiring Terminals:
Meter support wiring type, three-phase four-wire 4CT (3P4W_4CT), three-phase four-wire 3CT(3P4W_3CT), three-phase three-wire 3CT (3P3W_3CT), three-phase three-wire 2CT (3P3W_2CT),one-phase three-wire (1P3W), one-phase two-wire (1P2W)
Three-phase four-wire 3CT
Three-phase three-wire 3CT
Weight 0.7 kg
Primary current
100A, 200A, 50A
Power Meter Type
ME231N2, ME337ND2, ME337ND3, ME337NR2
Rogowski Coils
MRC-36, NRC-100, NRC-80
