Transducer With Bacnet &Modbus
Transducer node, Bacnet/Modbus over RS485,0-10v 4-20ma output signal
  • Applicable to all types of air environmental monitoring
  • HVAC systems
  • Advanced circuit design, high accuracy,stable performance
  • Appearance is concise,easy to install, cost-effective
Part number: XDUCER-W Category:
Wall transmitter is applicable to all kinds of building automation,environment monitoring, HVAC systems. Product appearance
is simple, direct connection terminals, convenient installation.Products use high performance embedded microprocessor, and high-precision sensors to meet all kinds of high precision,high stability of the temperature measurement requirements , and variety needs of different environments.Node sensor / transmitter has current,voltage, 485 output signal to select, using 485 serial port out put and Modbus communication protocol. It is commonly used in HVAC, electrical plant,environment monitoring,dynamic environment monitoring, agricultural environmental monitoring, meteorological environmental monitoring,environmental monitoring of biological pharmacy, airport,subway stations, hotel,museum,stadium, etc.
Weight 0.1 kg
AO
With AO, Without AO
Mount type
2 meter cable, Outdoor Mount, duct mount, wall mount
