Air Quality, Hum & Temp
  • The RS485 is hardened for overvoltage and power supply crossover amongst nodes
  • Display in degrees Fahrenheit or Celsius.
  • The bitmap LCD shows large & small text, symbols and other system data.
  • The user can configure many display options: network activity, baud rate, protocol, etc
  • Use this as a simple user interface in the zones to let the occupants adjust the setpoint up & down between the limits you choose.
  • RS485 Modbus and Bacnet protocols BOTH supported, easy integration with Bacnet controllers and VAVs.
  • Has 10V and 4-20ma output signals for traditional transducer based systems.
  • Handy free T3000 software for configuring all parameters and calibration.
$34.00 $42.00Price range: $34.00 through $42.00
Air Quality Humidity Temperature Monitor System
The Air Quality Humidity Temperature Monitor System is a compact, Node-style sensor designed for precise environmental monitoring in commercial and institutional buildings. Built for reliability and ease of integration, it offers real-time measurement and control of critical indoor climate parameters—ensuring healthier, safer, and more efficient spaces.
With support for Modbus and BACnet over RS485, the system delivers direct digital readings across all models. It also includes configurable 0–10V and 4–20mA transducer outputs, making it compatible with both modern and traditional building automation systems.
1. Advanced RS485 Communication
  • RS485 is hardened for overvoltage protection and power supply crossover, ensuring robust communication amongst multiple nodes.
  • Supports Modbus and BACnet protocols, enabling seamless integration with building automation systems, BACnet controllers, and VAV units.
2. Flexible Display Options
  • Choose between Fahrenheit or Celsius for temperature readings.
  • High-visibility bitmap LCD display shows large and small text, symbols, status indicators, and real-time system data.
  • Multiple user-configurable display options including network activity, baud rate, protocol, and more.
3. User-Friendly Interface
  • Can function as a simple zone interface for building occupants.
  • Users can easily adjust setpoint values within the limits that you configure—ideal for comfort control and energy management.
4. Versatile Output Signals
  • Provides both 0–10V and 4–20mA output signals, making it compatible with traditional transducer-based systems and modern digital networks.
5. Easy Configuration & Calibration
  • Comes with free T3000 software for effortless parameter setup, network configuration, and calibration adjustments.
Why Choose This System?
  • Reliable performance for indoor climate monitoring
  • Seamless integration with new and existing BAS systems
  • Compact design ideal for commercial and institutional environments
  • Multiple communication and output options for maximum flexibility
  • Intuitive interface for both technicians and building occupants
Wiring Diagram:Wiring Diagram of Air Quality Humidity Temperature Monitor
Dimension of Air Quality Humidity Temperature MonitorAir Quality Humidity Temperature Monitor
Weight 0.20 kg
LCD
with LCD, without LCD
You may also like…
