The Bacnet and modbus I/O modules work well with Seimens, Reliable, Delta, KMD, Tridium, etc.T3E-22i and T3E-886 support both Bacnet and Modbus over both RS485 and the ethernet ports.All settings are available as Bacnet objects and Modbus registers.
The T3E-32i has 32 inputs and the T3E-22i has 22 inputs. Both models share the same specifications except for the number of inputs. The wiring is slightly different though, each input on the T3E-22i has two terminals: one for the input signal and another for the ground. The T3E-32i on the other hand has ten more inputs, but it requires that the ground terminal be shared among two or more inputs.
Note:These are not routers, for general routing applications see the T3-BB controllers
Work with: Terminal shorting bar
