  • Dual communication support is provided via BACnet MS/TP and Modbus RS485, allowing flexible integration with HVAC and building management systems.
  • Output signals and RS485 communication lines are hardened against overvoltage and power supply cross-over conditions for improved operational safety.
  • Temperature values are displayed in either degrees Fahrenheit or Celsius, with configuration performed through BACnet connection.
  • A bitmap LCD display is utilized, allowing temperature readings, network connectivity status, and room setpoint information to be shown clearly.
  • Room setpoint values can be displayed, enabling the device to be used as a dedicated room temperature and setpoint display.
$38.00
43 in stock
Part number: RTS2-N-LCD Category:
Weight 0.1 kg
