Ball Valve Actuator
Actuator for 1/2″~1″, DN15~DN25 ball valve; operation time: about 45s(50Hz, 90 º), 24Vac
  • Bi-directional AC motor
  • Apply to valves of DN15 to DN25
  • Fire retardant engineering plastic, measure up UL94V-0 standard
  • Integrate with on-off switch at the end of stroke for longer motor life
  • With manual switch and position indicator
  • Electrical on/off type or floating (PID adjusting) type
  • Detachable design, easy to install and maintain
  • Good heat insulation design to avoid overheating inside of actuator
  • Reliable and high safety requirement level
  • 0(2)~10V dc or 0(4)~20mA dc control input signal, proportional control.
  •  0~10V feedback signal.
$34.50
Part number: SBA03-024 Category:
SBA03 series ball valve actuator is using bi-directional motor. Matching with SBV series ball valve, it is mainly used in central air-conditioning system, heating system,water treatment, and production industry to control the flow of chilled/hot medium
Weight 0.5 kg
