CO2 Sensor
CO2-D/CO2-W
CO2-N-TH
The CO2 sensor with Humidity & Temp transmitters are designed for environmental monitoring and controlling in industrial, commercial and other buildings. These transmitters can be used for indoor C02, temperature and humidity monitoring. The modbus interface provides easy setup and integration into large systems.Supports Modbus RTU over both the Ethernet port and the RS485 port,supports Bacnet over both the Ethernet port (IP) and the RS485 port (MSTP).
$72.00 - $156.50
| Weight | N/A |
| Enclosure | Duct, Node, Wall |
| Humidity | With Humidity, Without Humidity |
| Wifi | RS485 only, Wifi |
| POE | No POE, POE |
