The split core current transformer are used for monitoring power of large electrical loads and electrical services. Current flowing in the primary conductor creates a proportional current in the secondary output coil with a range of 0 to 5 amps. This is typically used to drive current indicators on large electrical panels. It is also compatible with commonly used power meters in the industry such as our Three Phase Power Meter.
are ideal where space is limited, such as when metering multiple loads within a panel board. Use for current measurement, energy metering, load surveys, demand metering, energy research, and submetering applications.
- 5A at secondary output, works with industry standard power meters.
- Clamping style makes for easy installation
- Secure locking hinge provides repeatable readings.
- Sub metering grade accuracy: 1%
- Small size, low cost
- Range Current:models from 100A up to 500A available
- UL file Number: E341727
$9.00 - $12.70
| Weight | N/A |
| Input | 1000A AC, 100A AC, 1200A AC, 200A AC, 300A AC, 400A AC, 500A AC, 600A AC, 700A AC, 800A AC |
| Output Signal | 1A AC, 5A AC |
