Duct Temperature Sensor – Flange Mount
This sensor is used to measure the supply and return temperature in HVAC system. The flange mount design makes it easy to install the sensor in tight quarters. There are several sensor elements to choose from which guarantee compatibility with all popular DDC systems. The probe in the photo is our standard model which is always in stock, it has a 8″ probe and a 120″ cable, and employs either a precision thermistor or platinum film sensor, so field calibration is not required. The 10ft(3m) cable is “Plenum Rated”.
  • High quality unit manufactured to high standards
  • Using materials and assembly techniques.
  • The probe material is stainless steel with a welded and ground tip.
  • The DTS probe is baked and then epoxy sealed to eliminate long term moisture problems.
  • The flange accepts two #6 screws, and is made from galvanized steel.
$5.00 - $8.00
Flange Mount Duct Temperature Sensor
The sensor is a high quality unit manufactured to high standards, using materials and assembly techniques. The probe material is stainless steel with a welded and ground tip.The DTS probe is baked and then epoxy sealed to eliminate long term moisture problems. The flange accepts two #6 screws, and is made from galvanized steel.
dts-flpartnum
