  • High performance digital sensors and circuits, ensure accurate measurement and temperature compensation
  • Good long-term stability and reliability
  • 100% field changeable sensors, no re-calibration needed
  • Fast response
  • Multiple output signals selectable: 4~20mA, 0~5V, or 0-10V
  • Supports Both Modbus and Bacnet over RS485 and Wifi, with an etrernet port.
  • Modbus communications port: RTU, 9.6k/19.2k/38.4k/57.6k/115.2kBaud
  • Display Highly configurable to show user assigned parameters and units,Degc or De gf
  • Filter: Sintered Stainless steel, 60um pore size
$34.00 - $58.50
These transmitters can be used for indoor air temperature and humidity monitoring in various industrial plant, clean room, lab, machine room, commercial buildings, airport, and schools. The modbus interface is documented and integrator friendly. They also have transducer outputs for connecting as analog inputs to all popular control systems. Various models are available: Duct Mount,Wall Mount,Room Mount and 2 meter cable. BACnet MS/TP and Modbus RTU protocols over RS485,with an ethernet port.
industrial humidity and temperature transmitter
wiring diagram of Humidity and Temp Transmitters
Stucture Graphic
structure graphic of Humidity and Temp Transmitters
part number of Humidity and Temp Transmitters
Dimensions
Dimensions of Humidity and Temp Transmitters
In conclusion, Humidity and Temp Transmitters provide versatile and dependable solutions for precise indoor air monitoring in industrial plants, laboratories, commercial buildings, airports, schools, and other critical environments. Equipped with integrator-friendly transducer outputs, these transmitters easily connect as analog inputs to all popular control systems, ensuring seamless integration and reliable performance.
With support for Modbus RTU, BACnet MS/TP protocols over RS485, and an Ethernet port, they offer flexible communication options to meet modern building automation needs. Available in multiple models, including Duct Mount, Wall Mount, Room Mount, and with a 2-meter cable, these transmitters deliver accurate temperature and humidity measurement while simplifying installation and maintenance.
Designed for durability and efficiency, Humidity and Temp Transmitters are ideal for maintaining optimal indoor air quality and ensuring safe, comfortable, and controlled environments in a wide range of applications.
Mount type
2.0 meter cable&remote display, duct mount, node, room mount, wall mount
