The Over Molded Floor Heating Sensor delivers precise temperature monitoring, high durability, and reliable performance for residential and industrial floors
    • Cable Temperature range: -50℃∽+105℃
    • Waterproof rated to IP68</li></li><li>Custom versions available in other sensor types
</ul>
$5.50
175 in stock
Part number: OMS-4.5-7 Category:
The over molded temperature sensor is typically used for in floor heating systems but is useful for many hot water heating applications. The sensor uses a 10K Type 2 thermistor with a 4.5m cable, rated for temperatures up to 105°C.
The over molded design allows this sensor to withstand wet environments for extended periods. This durability makes it suitable for agricultural projects and other demanding applications. The cable is tough and flexible so its easy to lay flat under flooring or strapped to the heating pipework.
Dimension:Dimension of Over molded Floor Heating Sensor
Weight 0.045 kg
