The pressure transmitter is designed for industry application with perfect long term stability,which is the most important specification for industry application.
Single Ended Pressure Transmitter is a kind of standard and most popular transmitter applied in air and liquid pressure measuring,since a high sensitivity silicon pressure chip is employed in the sensor.
$38.00 - $71.00
Weight | 0.39 kg |
Pressure range | 0-100[0.7Mpa], 0-250[1.8Mpa], RTD2, 0-1000[6.9MPa], 0-2000[13.8MPa], 0-2900[20MPa], 0-400[2.8MPa], 0-700[4.8MPa] |
