RS485 Lightning Protector
RS485 Lightning Protector is used for lightning protection of data communication system.
  • Large current handling capacity
  • High speed response
  • Low insertion loss
Specifications:
$10.00
8 in stock
Part number: SA-RS485 Category:
RS485 Lightning Protector safeguards data communication systems by protecting four signal lines or two twisted-pair connections from lightning. It provides both high-energy and low-energy protection, ensuring coarse and fine protection for data lines against surges and lightning impact.
It provides fine line-to-line protection as well as line-to-ground protection for lines 1, 2 and 3, 4, effectively taking in and sending away the energy from lightning and surges. The grounding cable safely directs the excess energy into the earth, protecting sensitive electronic equipment from damage. The device protects all RS485 data and composite video signal transmission systems from over-voltage.
  • Large Current Handling Capacity – Efficiently manages high current without performance loss
  • High-Speed Response – Reacts quickly to surges and lightning events
  • Low Insertion Loss – Ensures minimal signal loss for optimal data transmission
Wiring Connection:
Wiring image of RS485 Lightning Protector
Dimension:Dimension of RS485 Lightning Protector
Weight 0.08 kg
