Ball Valve Actuator
Actuator for 1/2″~1″, DN15~DN25 ball valve; operation time: about 45s(50Hz, 90 º), 24Vac
  • Bi-directional AC motor
  • Apply to valves of DN15 to DN25
  • Fire retardant engineering plastic, measure up UL94V-0 standard
  • Integrate with on-off switch at the end of stroke for longer motor life
  • With manual switch and position indicator
  • Electrical on/off type or floating (PID adjusting) type
  • Detachable design, easy to install and maintain
  • Good heat insulation design to avoid overheating inside of actuator
  • Reliable and high safety requirement level
  • 0(2)~10V dc or 0(4)~20mA dc control input signal, proportional control.
  •  0~10V feedback signal.
$34.50
Out of stock
Part number: SBA03-024 Category:
SBA03 series ball valve actuator is using bi-directional motor. Matching with SBV series ball valve, it is mainly used in central air-conditioning system, heating system, water treatment, and production industry to control the flow of chilled/hot medium
Wiring Diagram of SBA03 series ball valve actuator
Dimensions of SBA03 series ball valve actuator
The SBA03 ball valve actuator ensures precise, reliable, and efficient control of chilled or hot medium flow. Compatible with SBV series ball valves, the SBA03 actuator ensures smooth operation in HVAC and heating systems. It also provides reliable flow control for water treatment facilities and various industrial production applications.
This actuator delivers reliable performance, improves system efficiency, and lowers maintenance, making it ideal for industrial and commercial use.
Weight 0.5 kg
