Terminal Shorting Bar
The Terminal Shorting Bar (10-pin) lets you run a common conductor across multiple Temco T3 controller terminals. It has a high-temperature ABS cover and can be cut for shorter runs or combined for longer ones.
  • Specs: 10 pin shorting strip
  • Spacing: 3.1mm
  • Material: Galvanized steel, 0.8mm thickness,2.1mm width
  • Insulation: UL listed ABS
  • Maximum Current: 10 amps
  • Maximum Voltage: 110VAC
$0.55
157 in stock
Part number: TSB Category:
Terminal Shorting Bar – 10 Pin
The Terminal Shorting Bar is designed to help you create a clean and simple connection across multiple terminals. This 10-pin strip allows you to run a common conductor through several terminals on any Temco T3 series controller or I/O module. It offers a reliable way to link points together without messy wiring or extra jumpers.
We use strong galvanized steel for the bar and cover it with high-temperature, UL-listed ABS insulation for added safety. It comes in a 10-pin version, and you can cut it down for shorter setups or combine multiple strips for longer runs. This gives you flexibility for many different wiring needs while keeping everything neat, secure, and efficient.
Product Highlights
  • Specs: 10-pin shorting strip
  • Spacing: 3.1mm between pins
  • Material: Galvanized steel, 0.8mm thickness, 2.1mm width
  • Insulation: UL-listed ABS for high-temperature protection
  • Max Current: 10 amps
  • Max Voltage: 110 VAC
  • Flexible Use: Cut for shorter runs or join strips for longer setups
  • Compatible With: Temco T3 series controllers and I/O modules
Size:
tsb_dimension
Application:
tsb_7_web
work with: i/o module
Weight 0.01 kg
