• 2 analog outputs, 0-10V @ 100ma.
• Color LCD display
$45.00 - $89.00
Part number: Tstat10 Category:
This full-featured thermostat is designed for cooling and heating systems in residential and commercial buildings. The thermostat can be programmed for use with air handlers, fan coils,VAV, modulating valves and practically any HVAC application. All models support bacnet and modbus protocols which allows easy integration with the big name control systems like Niagara, Siemens, Honeywell, Johnson Controls, Delta, Reliable and Kreuter to name a few. There are five relays and two analog outputs as well as 8 universal inputs. The Tstat10 controllers can be configured and programmed using our free T3000 software. Once the unit is programmed you can save the program file and load it to other controllers. The device will perform its job as part of a networked system or can act as a standalone controller. There is no need for a master controller or connection to any cloud services to function hands free for the  life of the building.
Options are available for occupancy sensor, Wifi, and humidity / enthalpy. Supports Bacnet MSTP and Modbus RTU over RS485 and Bacnet IP on the wifi versions.
The source code for this product is open source so you can customize it with your own features. Here’s the repository on github: https://github.com/temcocontrols/T3-programmable-controller-on-ESP32
WiringDiagram
Weight 0.25 kg
LCD
with LCD, without LCD
C02
C02, No CO2
OCC
NO OCC, OCC
TVOC
No TVOC, TVOC
