PC Android touch screen 7” is a wall-mountable or Desk Mountable design with no external buttons. which offers all-round protection to prevent from shock, dust and water.All interfaces are equipped with protective components to cope with complex industrial environment.
-CPU: ARM Cortex A7 Dual-Core, 1.2Ghz
-OS: Android 6.0
-RAM: 2GB
-Display: 7 Inch IPS Display, Resolution:1024 x 600, Brightness: 360 nit
-Support multi-languages
$280.00 - $286.00
7 Inch Android touch screen PC is a wall-mountable or Desk Mountable design with no external buttons. The unit supports RJ45 (Ethernet LAN interface) with a DC In 9V-36V.   The unit also supports built-in POE (fully complaint with 802.3 af) support. Various mounting options exist including  in-wall flush,  on-wall and desktop  mounting ability.
The unit is available in white or black colors. Powered by the powerful 1.2GHz ARM Cortex Dual Core processor, this tablet is designed to give you high performance with long shelf life and is designed to operate on a 24×7 basis. Moreover, the tablet features 1GB RAM and 8GB ROM, which can be extended up to 32GB of storage with a MicroSD card.
Tablet with POE
Power Over Ethernet refers to the existing Ethernet Cat.5 cabling infrastructure without any changes in the circumstances, for some IP-based terminals (such as IP phones, wireless LAN access points AP, network cameras Etc.) to transmit data signals at the same time, but also for such equipment to provide DC power supply technology.
POE two power supply methods :
  • Mid -Span ( Using a stand-alone PoE powered device, spanning between the switch and the PoE-enabled terminal device, typically uses an unused idle pair of Ethernet cables to carry direct current )
  • End-Span  ( It is the power supply equipment integrated in the switch signal exit, such an integrated connection generally provides Idle line and data line pairs “dual” power supply.)7 Inch Android touch screen PC
In conclusion, the 7 Inch Android touch screen PC delivers reliable performance with versatility, durability, and smart connectivity.
Mount type
Basic model, Desktop mount, Inwall mount, Onwall mount
