Dual communication support is provided via BACnet MS/TP and Modbus RS485, allowing flexible integration with HVAC and building management systems.
Output signals and RS485 communication lines are hardened against overvoltage and power supply cross-over conditions for improved operational safety.
Temperature values are displayed in either degrees Fahrenheit or Celsius, with configuration performed through BACnet connection.
A bitmap LCD display is utilized, allowing temperature readings, network connectivity status, and room setpoint information to be shown clearly.
Room setpoint values can be displayed, enabling the device to be used as a dedicated room temperature and setpoint display.
$38.00
41 in stock
| Weight | 0.1 kg |
