CO2 Sensor
  • High performance digital sensors and circuits, ensure accurate measurement and temperature compensation
  • Good long-term stability and reliability
  • 100% field changeable sensors, no re-calibration needed
  • Fast response
  • Multiple output signals selectable: 4~20mA, 0~5V, or 0-10V
  • Supports Modbus RTU over both the Ethernet port and the RS485 port,supports Bacnet over both the Ethernet port (IP) and the RS485 port (MSTP).
  • Modbus communications port: RTU, 9.6k/19.2k/38.4k/57.6k/115.2kBaud
  • Display in degrees F or C
  • CO2 D/W probe: Pluggable sensor module with stainless steel sintered filter which can easily swap the sensor in the field.
  • CO2 Node : Bacnet MS/TP
  • Automatic background calibration, default CO2 value: 40000ppm
$72.00 - $133.00
CO2 is a core indicator of indoor air quality.It is used for energy-efficient control insmart ventilation systems, and can also beintegrated into air monitoring andpurification equipment for real-time indoorair quality monitoring.
CO2-D1/CO2-W1
CO2-N
Enclosure
Duct, Wall, Indoor wall mount
