The CS series Current Sensors are solid state transducers for measuring the current in fans, pumps and other HVAC equipments.
  • Self-powered, no external power supply required.
  • 0~5VDC output, connects directly to automation systems.
  • One sensor for three ranges, jumper selected.
  • Low cost, replaces digital status relays.
  • Panel mounting
  • UL file number:E341727,Vol 1
$16.60
Part number: N/A Categories: , ,
Current sensor output signal from these low-cost sensors provides an efficient solution for monitoring single-phase AC loads. They contain an AC rectifier circuit to directly output a 0 to 5VDC signal and require no power supply. Three full-scale ranges are available on the device for flexible current monitoring. Simply move the jumper to switch between 10A, 20A, and 50A full scale.
The output signal is proportional to the average current and may vary slightly from RMS ammeter readings depending on the load.
Note: If you are sensing low currents below 10A, you can wrap the primary cable through the hole twice, which makes the full-scale current 5A. If you can fit 10 wraps of the primary, this becomes a 1A full-scale sensor.
The sensor is a non-clamping style and is on sale for clearance since we have a new clamping/split-core current transformer which is easier to install.
Current sensor output signal with detailed dimensions for installation and monitoring single-phase AC loads.
Dimensions of current sensor output signal device for easy installation and AC load monitoring.
Current sensor output signal part number scheme for easy identification and selection of AC load sensors
In summary, these low-cost sensors provide a reliable current sensor output signal for monitoring single-phase AC loads. Adjustable full-scale ranges make these sensors versatile for various AC load monitoring applications. Additionally, the non-clamping design allows easy installation without disconnecting current-carrying cables.
Weight 0.11 kg
Current sensor type
Clamping current sensor, Non clamping current sensor
You may also like…
