Tstat 7 Thermostat
This full-featured CPU based thermostat is designed for small cooling and heating air handling systems in residential and commercial facilities.
    • BACnet MS/TP and Modbus RTU protocols over RS485
    • Baud rates of 1.2k,4.8k,9.6k,14.4k,19.2k, 38.4k, 57.6k, 76.8k and 115.2k</li>
<li>Well docum
  • ented register list for easy integration with other systems.
  • 2 analog outputs, 0-10V @ 100ma.
  • Easily configure the thermostat for practically any application
  • Clock with infinite life super cap battery backup
  • Side panel enclosure for hiding control buttons, and override switch
  • License free, Open source T3000 front end for configuring and managing systems
Recommended only for replacements or expansion on existing projects,Tstat10 is the latest, suggested model
https://temcocontrols.com/shop/tstat10-bacnet-thermostat/
$56.00 - $60.00
Tstat 7 Thermostat
The Tstat 7 Thermostat is a full-featured, CPU-based thermostat designed for small cooling and heating air handling systems in both residential and commercial facilities. Its advanced design ensures precise control, reliable operation, and seamless integration with modern building automation systems.
  • Protocols & Connectivity: Supports BACnet MS/TP and Modbus RTU protocols over RS485 for easy integration with major control systems.
  • Baud Rates: Configurable from 1.2k to 115.2k, allowing flexible communication speeds.
  • Register Documentation: Well-documented register list simplifies integration with other systems and controllers.
  • Analog Outputs: 2 outputs, 0–10V @ 100mA, for precise device control.
  • Customizable Configuration: Easily configure the thermostat for practically any HVAC application.
  • Clock Backup: Infinite-life supercap battery ensures continuous timekeeping.
  • Side Panel Enclosure: Conceals control buttons and override switch for clean installation and secure operation.
  • Software: License-free, open-source T3000 front end for configuring, managing, and monitoring systems.
Why Choose the Tstat 7 Thermostat?
This combines robust CPU-based control, flexible communication protocols, and an easy-to-use configuration interface. Its compact design and side panel enclosure make it suitable for residential and commercial installations, while the open-source T3000 software provides a cost-effective solution for system management and integration.
Upgrade your HVAC system with the Tstat 7 Thermostat for reliable performance, precise control, and seamless connectivity.
Thermostats work with T3000 controller wiring diagram:
"</a
"Wiring
Thermostats work with no T3000 controller wiring diagram:
"</a
"</a
"Diagram
        Works with: Relay Board
Weight 0.2 kg
Module type
Basic model temperature and clock, Humidity, OCC
