Duct Temperature Sensor
Plastic Water Resistant Box:
Electrical Box:
The duct sensor is used to measure the supply and return air temperature in HVAC system. There are several sensor elements to choose from which guarantee compatibility with all popular DDC systems. There is a precision thermistor. The probes are epoxy sealed to prevent moisture from migrating into the probe. Field calibration is not generally required. The standard probe length is 12 inch. Custom probe lengths, wire types and sensor elements are available for large OEM projects. Ask about our plastics & metal manufacturing capabilities for custom housings as well.
$6.70 - $12.50
Electrical Box:
| Weight | 0.15 kg |
| Enclosure | Metal electrical box, Plastic waterproof |
| Probe Length | 12 inch, 2 inch, 4 inch, 6 inch, 8 inch |
| Temperature Curve | 100PT, 10K Type 2, 10K Type 3, 1K PT, 20K |
