  • Can be adjusted to switch at various flow rates
  • Uses an SPDT switch with high power rating for up to 3.5 A continuous, 21 A surge
  • Non-Corrosive plastic ABS cover
  • Brass Fittings
  • Stainless Steel Paddles
  • Temperature Range 0~120°C (32~248°F)
  • Max working pressure: 13.5 bar(193 psig)
$24.00
22 in stock
Part number: WFS Category:
High-Quality Water Flow Switch
Ensure reliable monitoring of your water and liquid systems with our High-Quality Water Flow Switch. Designed for durability and precision, this switch is ideal for industrial and commercial applications.
Key Features:
  • Adjustable Flow Rates: Can be set to switch at various flow rates to suit your system requirements.
  • Reliable SPDT Switch: Handles up to 3.5 A continuous and 21 A surge for dependable performance.
  • Durable Construction: Stainless steel paddles and brass fittings ensure long-lasting use.
  • Non-Corrosive Protection: ABS plastic cover prevents corrosion and protects internal components.
  • Wide Temperature Range: Operates efficiently from 0°C to 120°C (32°F to 248°F).
  • High Pressure Capacity: Max working pressure of 13.5 bar (193 psig) for demanding applications.
Applications:
Ideal for monitoring the flow of water, liquids, and ethylene glycol solutions, ensuring your systems operate safely and efficiently. Perfect for industrial, HVAC, and process control environments.
Why Choose Our Water Flow Switch?
Our water flow switch combines precision, durability, and versatility. With adjustable flow settings and robust materials, it offers reliable performance even in challenging conditions. Protect your systems, prevent damage, and maintain optimal operation with ease.
Dimension of Water Flow Switch
Wiring Diagram of Water Flow Switch
Weight 1.0 kg
