HVAC Contactors, UL : E246810
Definite purpose contactor is a robust and low cost switching device specifically designed for the heating,ventilating and air conditioning industry.
  • Switch loads starting at 20 Amps all the way up to 150 FLA
  • Available in  single pole, 2 poles, 3 poles and 4 poles
$8.00 - $20.00
HVAC contactors are the ideal choice for switching fans, pumps, compressors and other typical HVAC loads. They are popular with many large OEM manufacturers and controls contractors. We can brand these under your name or ours, the default item ships as a white box product with no branding.
HVAC contactors for efficient control of fans, pumps, and compressors
Durable HVAC contactor device used in heating and cooling systems
High-quality HVAC contactors for commercial and industrial applications
HVAC Contactor with visible part number for identification
Notes: The available auxiliary switches for 3- and 4-pole contactors MOQ is 200pcs. If you want to order, please contact us, the switches price is not on the web.
HVAC contactors offer a dependable solution for switching common HVAC loads and meeting the demands of OEM manufacturers and control contractors. With flexible branding options and reliable performance, HVAC Contactors ensure your systems operate smoothly while maintaining your desired brand identity.
Weight 0.45 kg
Contact rating
15A, 10 Amps, 2 Amps, 20 Amps, 20Amps, 25Amps, 30 Amps, 40 Amps, 5 Amps, 60Amps
Num of Poles
1 pole, 2 poles, 3 poles, 4 poles
Coil voltage
110VAC, 220VAC, 24VAC
