This full featured thermostat is designed for line voltage cooling and heating systems in residential and commercial buidings. The thermostat can be configured for or use with air handlers, fan cols, VAv, modulating valves and practically any HVAC application.All models support Bacnet and Modbus protocol over the Wif iP connection which aows easy integration with the big name control systems like Niagara, Siemens, Honeywel. lohnson Controls ,Delta,Reliable and Kreuter to name a few. We also provide our free and easy to use T3000 front end which can provide a full system level solution for large buildings, hotels and commercial buildings.There are five 220v, 5A rated relays outputs. These outputs can be configured using thefree software.There are more than 300 setings with many options for each other setings so its possilble to contgure these devices for most anvapplication. Once the unit is configured, save the config file for copying to other controlers and backing up project seltings. Options are available foroccupancy sensor, wifi, CO2 and humidity/enthalpy.
Wiring Diagram 1
Wiring Diagram 2
Wiring Diagram 3
Wiring Diagram 4
In conclusion, this full-featured HVAC thermostat offers unmatched flexibility and integration for both residential and commercial buildings. With support for BACnet and Modbus over WiFi, configurable relays, and advanced sensor options, it provides a reliable and efficient solution for any HVAC application. Its easy-to-use T3000 software ensures seamless setup and management, making this HVAC thermostat the ideal choice for modern building automation
