This Android panel PC is a wall-mountable or Desk Mountable design with no external buttons. The unit supports RJ45 (Ethernet LAN interface) with a DC In 9V-36V. The unit also supports built-in POE (fully complaint with 802.3 af) support.Various mounting options exist including in-wall flush, on-wall and desktop mounting ability. The unit is available in white or black colors.Powered by the powerful 1.2GHz ARM Cortex Dual Core processor, this tablet is designed to give you high performance with long shelf life and is designed to operate on a 24×7 basis. The tablet has 1GB RAM and 8 GB ROM extensible upto 32 GB of storage with MicroSD.
Tablet with POE
Power Over Ethernet refers to the existing Ethernet Cat.5 cabling infrastructure without any changes in the circumstances, for some IP-based terminals (such as IP phones, wireless LAN access points AP, network cameras Etc.) to transmit data signals at the same time, but also for such equipment to provide DC power supply technology.
POE two power supply methods :
- Mid -Span ( Using a stand-alone PoE powered device, spanning between the switch and the PoE-enabled terminal device, typically uses an unused idle pair of Ethernet cables to carry direct current )
- End-Span  ( It is the power supply equipment integrated in the switch signal exit, such an integrated connection generally provides Idle line and data line pairs “dual” power supply.)
