Plastic Switch Box
The Switch BOX series sealed box is suitable for various industrial applications and can be used as a sealed box, instrument case, control cabinet, illumination box, terminal box, or button box.
          • Protection level IP65
        <l&amp;amp;lt;/p&gt;
    </ul>
i&gt;Cert: CCC, CE, T</p>
      • UV,
RoHS
      • Flame retardant: V0
      • Material: ABS &
      • External Size:80x110x70mm</li>
      • Fit Round Switch Head Diameter:22mm
      • Screw thread Diameter:5mm
      • Color: white
      • One or two holes
$7.50$8.25
Plastic Switch Box
The Plastic Switch Box from the Switch BOX series is a durable and reliable sealed enclosure designed for a wide range of industrial and commercial applications. It is widely used in machinery and machine tools, electrical equipment, power systems, communication networks, and automation setups.
This versatile switch box is also suitable for demanding environments such as marine, metallurgy, chemical plants, aerospace, rail transportation, sewage treatment facilities, and architectural installations.
Depending on your application requirements, the Plastic Switch Box can be used as a sealed box, instrument case, field control cabinet, illumination box, terminal box, or button box, making it a flexible solution for multiple control and protection needs.
Key Features & Highlights
  • Protection Level: IP65 for dust and water resistance
  • Flame Retardant Material: V0 grade for enhanced safety
  • High-quality ABS material for durability and long service life
  • Suitable for one or two switch holes
  • Designed to fit round switch head diameter of 22mm
  • Strong and secure screw mounting system
Technical Specifications
  • Product Type: Plastic Switch Box
  • Material: ABS
  • Flame Retardant: V0
  • Certifications: CCC, CE, TUV, RoHS
  • External Size: 80 × 110 × 70 mm
  • Fit Round Switch Head Diameter: 22 mm
  • Screw Thread Diameter: 5 mm
  • Color: White
  • Hole Options: One hole or two holes
Applications
The Plastic Switch Box is ideal for use in:
  • Industrial machinery and machine tools
  • Electrical and power distribution systems
  • Automation and control panels
  • Communication equipment
  • Marine and offshore installations
  • Chemical and metallurgy industries
  • Aerospace and rail transportation systems
  • Sewage treatment plants
  • Architectural and illumination setups
Why Choose This Switch Box?
This offers a perfect balance of safety, durability, and flexibility. With IP65 protection, flame-retardant ABS material, and international certifications, it ensures reliable performance even in harsh environments while supporting multiple installation and usage requirements.
Plastic Switch Box
Work with: Momentary Push Button
Weight 0.77 kg
Plastic Switch Box
One hole,waterproof Plastic Switch Box, Two holes,waterproof Plastic Switch Box
