Duct temperature transmitter is applicable to all kinds of building automation, environment monitoring, and HVAC systems. Its simple design, direct connection points, and easy installation make it easy to use in various setups.
Therefore, the product uses a powerful built-in processor and accurate sensors to meet the needs of stable and correct temperature measurement in different environments.
ChatGPT said:
This Temperature Transducer with Bacnet and Modbus RS485 offers multiple output options, including current, voltage, and 485 signals, using the RS485 serial port with Modbus communication protocol. As a result, it is widely used in HVAC, electrical plants, dynamic and general environmental monitoring, agricultural and weather monitoring, biological lab environments, airports, subway stations, hotels, museums, stadiums, and more.
Dimension
Part Num Scheme
In conclusion, this duct temperature sensor is a simple, reliable, and highly useful device for many types of environments. Its easy installation, direct connection points, and strong performance make it ideal for both small and large systems. As a result, with accurate sensors and a strong processor, it ensures precise and stable temperature readings at all times.
ChatGPT said:
ChatGPT said:
Because it supports multiple output options, including current, voltage, and Modbus communication through an RS485 port, It fits easily into different building control and monitoring setups. Whether used in HVAC systems, environmental monitoring, electrical plants, airports, hotels, or agricultural spaces, it consistently delivers reliable results.
