Tstat 2 Series Thermostat
TSTAT 2 series on/off thermostat is mainly used in central air-conditioning heating and cooling system. It works with TSC series temperature sensor. It provides temperature control for central air-conditioning fan coil cooling / heating motorized valve or other electric actuator by the control signal which produced by comparison of actual tested ambient temperature and setting temperature.
- Power surge and instant pulse protection.
 - LCD showing ambient temperature, state and air volume.
 - With system switch and fan speed switch.
 - Built-in or external long-distance temperature sensitive element (NTC thermistor).
 - With ABS fireproof plastic, in compliance with UL-94V0 standard.
 - With flexible installation and convenient wiring.
$20.50 - $20.50
