Dual Float Switch
The float switch is a device used to sense the level of water within a tank,and it can actuate a pump,an indicator, an alarm, or other device.
  • Good price & high quality
  • Contains no mercury
  • Flipped over avaliable
$25.00 - $35.00
The dual float switch works with hydroponics, saltwater tanks, freshwater tanks, and gardening systems. It also supports aquariums, fish tanks, filtration, heating, and many other water-control projects.
Note: Right now we just have a few standard models on the site so you can see the rough pricing. For custom units you can send on a description or better yet, a sketch and we’ll quote it out right away. Customizing is not expensive but we may ask for a minimum quantity.
Part Number Scheme:Part Number Scheme of Dual Float Switch
In conclusion, the Dual Float Switch is a simple and reliable tool for many water projects. It helps you control water levels with ease. You can use it for tanks, gardens, or any setup that needs steady water control. It is also a good choice if you want a safe and smooth system.
The models on the site show the basic pricing. These models help you understand what to expect. If you need something different, you can always ask for a custom unit.
Weight 0.20 kg
dual float switch length
250mm/ 9.8in, 500mm/ 19.7in, 600mm/ 23.6in
